Errore durante l'apertura porte TP-LINK HR340G
Bonezinho
Digito nel browser: http://192.168.1.1. Poco dopo Advanced Settings>Forwarding>Virtual Servers>Add New. ho messo il Add New Port (81) e il PI, poi SALVA. apaece questo errore: The IP address is not in the same subnet with the LAN! (Italiano)​
Erro ao abrir porta TP-LINK HR340G
Digito no navegador: http://192.168.1.1. Logo depois Advanced Settings>Forwarding>Virtual Servers>Add New. Coloco a porta (81) e o IP, depois em SAVE. apaece esse erro: The IP address is not in the same subnet with the LAN! (Português)​
Error opening port TP-LINK HR340G
I type in the browser: http://192.168.1.1. Soon after Advanced Settings> Forwarding> Virtual Servers> I put the Add New Port (81) and the IP, then SAVE. apaece this error: The IP address is not in the Same subnet with the LAN!
i’d like to know what is your favourite language, but maybe you can translate this with google 😛
what IP are you trying to forward a port to? is that the ip of a device with internet access? does it works (the internet from that device)?
