massimo6342
Hi there, I tried to use the ZTE MF 710 with the TL-MR3020 to no success. The router is updated to the last firmware and the modem is brand new. The router declares the modem as “identified” but trying to connect is a waste of time. The led on the modem does not even blink. I tried both automatic configuration and manual configuration to no success. The same modem when connected to my computer works fine. Any idea if the two are in any way compatible? Thank you very much for your help, Massimo
