[Risolto]MR-3420 - Huawei e3276s-150 - Alternatyva
Non riesco a collegarmi con la chiavetta 4G E3276s-150, il router (versione firmware V2_140309) la riconosce ma non riesce ad ottenere il collegamento alla rete Wind.
La mia SIM è stipulata con un operatore virtuale che si affida alla rete wind, si tratta di Alternatyva.
La chiavetta inserita in un PC Windows funziona sia con SIM Alternatyva sia con SIM 3, ma collegata al router posso accedere ad internet solo con tramite 3.
Questo è il log con SIM 3:
1st day 00:05:18	 3G/4G     	INFO   	USB modem is ready
1st day 00:05:25	 3G/4G     	NOTICE 	3G/4G start connecting...
1st day 00:05:25	 3G/4G     	INFO   	swLteMobileCmdReq 420 lteLinkStatus == 0
1st day 00:05:25	 3G/4G     	INFO   	Set APN datacard.tre.it and authType 0x2
1st day 00:05:30	 3G/4G     	NOTICE 	swLteMobileCmdReq 476 call dhcpcLteModemStart
1st day 00:05:30	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:05:30	 DHCP      	INFO   	DHCPC Recv OFFER from server a574261 with ip a574267
1st day 00:05:30	 DHCP      	INFO   	DHCPC Send REQUEST to server a574261 with request ip a574267
1st day 00:05:30	 DHCP      	INFO   	dhcpc_ipc_data_rcv_router 743 : current network type = 1
1st day 00:05:30	 DHCP      	INFO   	dhcpc_ipc_data_rcv_lte 258 lte_net_info.status = 0x1 lte_net_info.ip = 0x0, lte_net_info.mask = 0x0, lte_net_info.gw = 0x0
1st day 00:05:31	 DHCP      	INFO   	DHCPC Recv ACK from server a574261 with ip a574267 lease time 518400
1st day 00:05:31	 DHCP      	INFO   	DHCPC:GET ip:a574267 mask:fffffff0 gateway:a574261 dns1:3e0dad5e dns2:3e0dad5f static route:0
1st day 00:05:31	 DHCP      	INFO   	dhcpc_ipc_data_rcv_router 743 : current network type = 1
1st day 00:05:31	 DHCP      	INFO   	dhcpc_ipc_data_rcv_lte 258 lte_net_info.status = 0x0 lte_net_info.ip = 0xa574267, lte_net_info.mask = 0xfffffff0, lte_net_info.gw = 0xa574261
1st day 00:05:31	 DHCP      	INFO   	dhcpc_ipc_data_rcv_lte 317 dhcpstr.ip = 10.87.66.97
1st day 00:05:31	 DHCP      	INFO   	Update DNS1 = 0x3e0dad5e, DNS2=0x3e0dad5f
1st day 00:05:32	 DHCP      	WARNING	dhcpc_ipc_data_rcv_lte 367
1st day 00:05:32	 DHCP      	INFO   	LTE Network connected.
Mentre questo è l’output con Alternatyva:
1st day 00:16:49	 3G/4G     	INFO   	USB modem reset, please wait.
1st day 00:16:49	 OTHER     	NOTICE 	Clear the USB PORT
1st day 00:16:49	 3G/4G     	INFO   	handle_card start
1st day 00:16:49	 3G/4G     	INFO   	LTE Modem = 0, modemStatus = 1, targetVendorID = 0x0000, targerProductID = 0x0000
1st day 00:16:51	 3G/4G     	INFO   	LTE Modem = 0, modemStatus = 0, targetVendorID = 0x0000, targerProductID = 0x0000
1st day 00:16:51	 3G/4G     	INFO   	process_msg 457 : call dhcpcLteModemRelease
1st day 00:16:53	 3G/4G     	NOTICE 	dhcpcLteModemRelease 1200 sysCmd = ifconfig lte0 0.0.0.0
1st day 00:16:54	 3G/4G     	INFO   	Modem is plugged out.
1st day 00:17:02	 3G/4G     	INFO   	handle_card start
1st day 00:17:02	 3G/4G     	INFO   	LTE Modem = 0, modemStatus = 1, targetVendorID = 0x0000, targerProductID = 0x0000
1st day 00:17:11	 3G/4G     	INFO   	Before Mode switch VendorID = 0x12d1, ProductID = 0x14fe
1st day 00:17:11	 3G/4G     	DEBUG  	=>
1st day 00:17:11	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
1st day 00:17:11	 3G/4G     	DEBUG  	=>B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
1st day 00:17:11	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
1st day 00:17:11	 3G/4G     	DEBUG  	=>P:  Vendor=1d6b ProdID=0002 Rev= 2.06
1st day 00:17:11	 3G/4G     	DEBUG  	=>S:  Manufacturer=Linux 2.6.31--LSDK-9.2.0_U5.508 ehci_hcd
1st day 00:17:11	 3G/4G     	DEBUG  	=>S:  Product=ATH EHCI
1st day 00:17:11	 3G/4G     	DEBUG  	=>S:  SerialNumber=platform
1st day 00:17:11	 3G/4G     	DEBUG  	=>C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
1st day 00:17:11	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
1st day 00:17:11	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
1st day 00:17:11	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  8 Spd=480 MxCh= 0
1st day 00:17:11	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
1st day 00:17:11	 3G/4G     	DEBUG  	=>P:  Vendor=12d1 ProdID=14fe Rev= 1.02
1st day 00:17:11	 3G/4G     	DEBUG  	=>S:  Manufacturer=HUAWEI Technology
1st day 00:17:11	 3G/4G     	DEBUG  	=>S:  Product=HUAWEI Mobile
1st day 00:17:11	 3G/4G     	DEBUG  	=>C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
1st day 00:17:11	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
1st day 00:17:11	 3G/4G     	DEBUG  	=>E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:11	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:11	 3G/4G     	DEBUG  	=>I:* If#= 1 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
1st day 00:17:11	 3G/4G     	DEBUG  	=>E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:11	 3G/4G     	DEBUG  	=>E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:11	 3G/4G     	INFO   	This is a LTE modem which needs mode switch.
1st day 00:17:15	 3G/4G     	DEBUG  	try cmd = usb_modeswitch -v 0x12d1 -p 0x14fe -I -W -c /tmp/3G/12d1_14fe_0 &^M
1st day 00:17:24	 3G/4G     	DEBUG  	echo "/tmp/3G/12d1_14fe_0:55534243123456780000000000000011062000000100000000000000000000" > /tmp/3G/switch_cmd_file
1st day 00:17:24	 3G/4G     	DEBUG  	Before judgeModemTypeByTargetID, index = 11, targetPid = 0x1506
1st day 00:17:24	 3G/4G     	DEBUG  	=>
1st day 00:17:24	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
1st day 00:17:24	 3G/4G     	DEBUG  	=>B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
1st day 00:17:24	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
1st day 00:17:24	 3G/4G     	DEBUG  	=>P:  Vendor=1d6b ProdID=0002 Rev= 2.06
1st day 00:17:24	 3G/4G     	DEBUG  	=>S:  Manufacturer=Linux 2.6.31--LSDK-9.2.0_U5.508 ehci_hcd
1st day 00:17:24	 3G/4G     	DEBUG  	=>S:  Product=ATH EHCI
1st day 00:17:24	 3G/4G     	DEBUG  	=>S:  SerialNumber=platform
1st day 00:17:24	 3G/4G     	DEBUG  	=>C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  9 Spd=480 MxCh= 0
1st day 00:17:24	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
1st day 00:17:24	 3G/4G     	DEBUG  	=>P:  Vendor=12d1 ProdID=1506 Rev= 1.02
1st day 00:17:24	 3G/4G     	DEBUG  	=>S:  Manufacturer=HUAWEI Technology
1st day 00:17:24	 3G/4G     	DEBUG  	=>S:  Product=HUAWEI Mobile
1st day 00:17:24	 3G/4G     	DEBUG  	=>C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=10 Driver=(none)
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=03(Int.) MxPS=  64 Ivl=2ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=(none)
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:  If#= 2 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=02 Prot=16 Driver=cdc_ncm
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=84(I) Atr=03(Int.) MxPS=  64 Ivl=2ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 2 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=cdc_ncm
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	=>E:  Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:24	 3G/4G     	DEBUG  	3GEther is 1
1st day 00:17:25	 3G/4G     	DEBUG  	Modem vendorID = 0x12d1, productID = 0x14fe, switch cmd = /tmp/3G/12d1_14fe_0
1st day 00:17:25	 3G/4G     	INFO   	After mode switch vendorID is 0x12d1 productID is 0x1506
1st day 00:17:25	 3G/4G     	DEBUG  	card_add 877  minfo.modeswitchcmd = /tmp/3G/12d1_14fe_0 minfo.simLock = 0, minfo.modemChipTyp = 0
1st day 00:17:25	 3G/4G     	INFO   	Before judgeModemTypeByTargetID, index = 11, targetPid = 0x1506
1st day 00:17:25	 3G/4G     	DEBUG  	3GEther is 1
1st day 00:17:25	 3G/4G     	INFO   	After judgeModemTypeByTargetID, modem type = 2
1st day 00:17:25	 3G/4G     	INFO   	LTE Modem = 2, modemStatus = 2, targetVendorID = 0x12d1, targerProductID = 0x1506
1st day 00:17:25	 3G/4G     	INFO   	insmod LTE modem drivers
1st day 00:17:26	 3G/4G     	DEBUG  	=>
1st day 00:17:26	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
1st day 00:17:26	 3G/4G     	DEBUG  	=>B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
1st day 00:17:26	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
1st day 00:17:26	 3G/4G     	DEBUG  	=>P:  Vendor=1d6b ProdID=0002 Rev= 2.06
1st day 00:17:26	 3G/4G     	DEBUG  	=>S:  Manufacturer=Linux 2.6.31--LSDK-9.2.0_U5.508 ehci_hcd
1st day 00:17:26	 3G/4G     	DEBUG  	=>S:  Product=ATH EHCI
1st day 00:17:26	 3G/4G     	DEBUG  	=>S:  SerialNumber=platform
1st day 00:17:26	 3G/4G     	DEBUG  	=>C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  9 Spd=480 MxCh= 0
1st day 00:17:26	 3G/4G     	DEBUG  	=>D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
1st day 00:17:26	 3G/4G     	DEBUG  	=>P:  Vendor=12d1 ProdID=1506 Rev= 1.02
1st day 00:17:26	 3G/4G     	DEBUG  	=>S:  Manufacturer=HUAWEI Technology
1st day 00:17:26	 3G/4G     	DEBUG  	=>S:  Product=HUAWEI Mobile
1st day 00:17:26	 3G/4G     	DEBUG  	=>C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=10 Driver=usbserial_generic
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=81(I) Atr=03(Int.) MxPS=  64 Ivl=2ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=usbserial_generic
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:  If#= 2 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=02 Prot=16 Driver=cdc_ncm
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=84(I) Atr=03(Int.) MxPS=  64 Ivl=2ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 2 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=cdc_ncm
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usbserial_generic
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usbserial_generic
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:26	 3G/4G     	DEBUG  	=>E:  Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
1st day 00:17:29	 3G/4G     	NOTICE 	3G/4G start connecting...
1st day 00:17:29	 3G/4G     	INFO   	swLteMobileCmdReq 420 lteLinkStatus == 0
1st day 00:17:30	 3G/4G     	DEBUG  	lteModemATCommandGetPinStatus 284 modem name is /dev/ttyUSB0
1st day 00:17:31	 3G/4G     	DEBUG  	parseResponseBuf 246 Respone data is: at+cpin?^M^M +CPIN: READY^M ^M OK^M  , len = 31
1st day 00:17:31	 3G/4G     	DEBUG  	lteModemATCommandGetPinStatus 302 ret = 0, bufPinMsg = at+cpin?^M^M +CPIN: READY^M ^M OK^M
1st day 00:17:31	 3G/4G     	INFO   	USB modem is ready
1st day 00:17:59	 3G/4G     	NOTICE 	3G/4G start connecting...
1st day 00:17:59	 3G/4G     	INFO   	swLteMobileCmdReq 420 lteLinkStatus == 0
1st day 00:17:59	 3G/4G     	INFO   	Set APN mobile.alternatyva.static.it and authType 0x2
1st day 00:18:04	 3G/4G     	NOTICE 	swLteMobileCmdReq 476 call dhcpcLteModemStart
1st day 00:18:04	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:18:04	 DHCP      	INFO   	dhcpc_ipc_data_rcv_router 743 : current network type = 1
1st day 00:18:04	 DHCP      	INFO   	dhcpc_ipc_data_rcv_lte 258 lte_net_info.status = 0x1 lte_net_info.ip = 0x0, lte_net_info.mask = 0x0, lte_net_info.gw = 0x0
1st day 00:18:06	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:18:08	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:18:12	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:18:14	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:18:16	 DHCP      	INFO   	DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:18:16	 DHCP      	INFO   	dhcpc_ipc_data_rcv_router 743 : current network type = 1
1st day 00:18:16	 DHCP      	INFO   	dhcpc_ipc_data_rcv_lte 258 lte_net_info.status = 0x2 lte_net_info.ip = 0x0, lte_net_info.mask = 0x0, lte_net_info.gw = 0x0
1st day 00:18:16	 DHCP      	NOTICE 	dhcpc_ipc_data_rcv_lte 276 g_lteConTimes = 1
1st day 00:18:26	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:18:28	 DHCP      	INFO   	DHCPC Send DISCOVER with request ip 0 and unicast flag 0
Che mi dite?
Ciao, è un problema che hanno molti router 3G/4G con Alternatyva.
Senti la loro assistenza perchè se non sbaglio nelle impostazioni della connessione devi cambiare il numero e inserire nome utente e password.
Grazie effeti per la risposta.
Ho dimenticato di dire che sino ad oggi mi sono collegato senza problemi con il router MR3420 e la chiavetta MA260 con inserita la SIM Alternatyva; i parametri di accesso non li ho modificati, dovrebbero valere anche per la E3276.
Dal log mi confermi che la richiesta che comunica alla rete è corretta?
Non riesco nemmeno a collegarmi da GNU/Linux attraverso connessione mobile broadband.
Guarda i log, la parte più importante è questa
H3G
ALTERNATYVA
A me non sembra un problema del router ma di autenticazione o rete Alternatyva.
La sim è abilitata alla rete LTE? Hai copertura LTE?
Questo può dipendere da molte cose (usb_modeswitch, driver, etc etc) ma non andiamo OT…
EDIT: Aspetta… ma la e3276 ha interfaccia HiLink?
La SIM è una 4G ma Alternatyva opera esclusivamente sul 3G, per cui ho impostato dal software Huawei: “WCDMA Only”
però non ho idea se questa impostazione la salvi sulla chiavetta per poi rispettarla una volta inserita nel router.
No, il firmware è l’ultimo disponibile, il 21.436.03.00.00 che dovrebbe essere la versione normale. Con l’HiLink risolverei qualcosa?
Si viene memorizzata nella chiavetta
Possibile, però ricordati che devi cambiare indirizzo ip al tp-link perchè non possono esserci due 192.168.1.1
Vai nel menu network lan e metti 192.168.10.1
Con l’HiLink la e3276s ha ip 192.168.1.1 aprilo con un browser per la configurazione della connessione 3G/4G
:confused: Hmmm, sulla rete si trovano tutorial per trasformare una E3276s-150 HiLink in una normale, ma il passaggio inverso non viene mai citato.
Nella guida che avrei scaricato da questi due pacchetti:
firmware e WebUI
vedo che tra le schede di rete dovrebbe comparire “Remote NDIS based Internet Sharing Device” ma a me appare “HUAWEI Mobile Connect - Network Card”, inoltre è presente pure una voce sotto modem.
Nell’applicazione installata ora è possibile impostare la chiavetta in modalità “RAS(modem)” oppure “NDIS”, ma la voce dei dispositivi rimane inalterata e non è possibile accedervi dall’indirizzo 192.168.1.1.
Che dici, mi arrischio a procedere con l’installazione di quel firmware? Ritieni che sia il più appropriato?
Ci sono riuscito! :smiley:
Installando il firmware che ho mostrato nel post precedente la chiavetta riesce a connettersi e a condividere il traffico al router. :smiley:
Gli ho collegato un’antenna esterna da pochi euri che però fa un eccellente lavoro, portando il segnale al massimo e consentendo di farmi raggiungere dei valori eccellenti.
speedtest a 24Mb/s
Con la MA260 non superavo gli 8Mb/s.
Son contento! :laughing:
Grazie mille, effeti.
Ottimo! :smiley:
Ricorda che puoi sempre vedere segnale, messaggi etc etc anche quando la chiavetta è collegata al router!
Devi aprire sempre http://192.168.1.1 è molto comodo…
Sì, decisamente un passo avanti rispetto alla luce accesa/spenta della chiavetta. :slight_smile:
Anche se mi piacerebbe sapere il valore esatto del segnale in Db, come aveva il software Huawei dell’altro firmware, strano che non l’abbiamo implementato nella WebUI. :frowning:
Comunque ormai ho già piazzato l’antenna esterna con il suo tassello e da lì non la sposto.
Per la stesura dell’elenco delle compatibilità, è stato abbandonato o ci si dedica ancora qualcuno?
Io ho fatto una prova andata a buon fine pure con l’hotspot portatile Huawei R215.
Non hai un menu simile?
E’ ancora attivo ma nessuno le segnala, se funziona nessuno ha 2 minuti di tempo per compilare il form…
No, in “Sistema” ho solo tre voci e “Stato della Rete” è assente.
Versione UI Web: 17.100.03.01.03
l
Ciao, non postare lo stesso messaggio in tutte le discussioni!
Decidi dove continuare perchè cosi non si capisce niente, hai scritto la stessa cosa qui:
https://www.in-rete.it/viewtopic.php?f=15&t=2594&p=18051#p18051
https://www.in-rete.it/viewtopic.php?f=15&t=2546&p=18058#p18058
https://www.in-rete.it/viewtopic.php?f=15&t=12&p=18056#p18052
