Powerline TL-PA101 V1 e V2
Caratteristiche:
  • High speed data transfer rate up to 85Mbps
  • Easy Plug-N-Play operation, use existing electrical wiring
  • Turn every power socket into a LAN port
  • Energy consumption is reduced by up to 30% in standby mode
  • Intelligent channel adaptation maximizes throughput under harsh channel conditions
  • Built-in QoS, prioritize the data, enabling smooth video streaming and lag-free gaming.
  • 56-bit DES encryption to secure powerline communications
  • Up to 200 meters range over the household power circuit for better performance through walls or across floors
  • User-friendly software for PC (Windows XP/2000/2003/Vista),
  • Backward compatible with HomePlug 1.0
Software:
TL-PA101 V1 utility: download.
TL-PA101 V2 utility: download.
